Hyper has announced the launch of its HyperJuice 18W Lightning and USB-C Battery Pack, described as the "world's first" battery with an integrated 18W Apple MFi Lightning and USB-C Cable.
Around the same size as the iPhone 11, the HyperJuice can charge an iPhone from empty to 50 percent charge in under 30 minutes, and comes with an integrated 18W USB-C cable that can charge any USB-C devices including iPad Pro and Android devices.
The 10,000mAh battery pack can be easily recharged at 18W speed using the same built-in USB-C cable or using an additional USB-C input charge port.
It also supports pass-through charging, so users can charge both their HyperJuice battery pack and iPhone at the same time using a single USB-C charger with the cables already built into the HyperJuice.
The battery pack has a 4-stage LED battery level indicator, and weighs just 225 grams. The HyperJuice USB-C + Lightning Battery Pack (10000mAh) is now available on HyperShop.com for US$59.99.
Note: MacRumors is an affiliate partner with Hyper. When you click a link and make a purchase, we may receive a small payment, which helps us keep the site running.
Top Rated Comments
