Satechi today announced a new 72W USB-C Car Charger and an Apple MFi-Certified USB-C to Lightning cable. The company said that with Power Delivery technology and USB-C, the 72W Car Charger supports quick charging of modern iPhones.
satechi new car charger
This means that you can get about 50 percent of charge on an iPhone 8 or later device in 30 minutes. Satechi's new car charger also has a regular USB-A port, so you can charge two devices at once. The USB-C port delivers fast charging up to 60W and the USB-A port delivers regular charging up to 12W.
You can buy the 72W USB-C Car Charger in Silver or Space Gray for $29.99, and the USB-C to Lightning Cable for $24.99. The cable features a length of six feet and a braided nylon construction to avoid tangles.
Note: MacRumors is an affiliate partner with Satechi. When you click a link and make a purchase, we may receive a small payment, which helps us keep the site running.
Tag: Satechi
Top Rated Comments
d5aqoëp Avatar
78 months ago
Has anyone done studies on how this can negatively affect car battery? I had Aukey car charger USB-PD 15W. My new car battery went off within 2 months. VW were terrible and kept saying that my car charger was to blame.
xanduxandu Avatar
78 months ago
72W and such small form factor, I don’t think is possible
Return Zero Avatar
78 months ago
Seriously? 6 amps this plastic will melt.
The amperage has nothing to do with the plastic and everything to do with conductor size. If this thing has internal wires/buses of proper size and material, 6 amps won't cause a significant temperature rise. I regularly work with conductors about the same diameter as my little finger that carry over 12,000 volts at over 150 amps yet remain within 5 degrees of ambient temperature.
33man Avatar
78 months ago
Time to remember power formula calculation
P=U*I
72W=12V*I
I = 72/12 = 6 Amps...
My two cents but I thing there is 72 W for half a second, so they can get validated product name/description but mostly will use max 0.5 amp
[doublepost=1565281057][/doublepost]
P=U*I
72W=12V*I
Haha it's 60 + 12
Attachment Image
RevTEG Avatar
78 months ago
I’m certainly not a battery expert but if you drive your car on a regular basis then you shouldn’t have any issues. The alternator recharged the car battery really fast. If driven regularly then the car charger shouldn’t have enough time to negatively harm your battery.
I once had a car charger that had a little green light that would stay on to show it was getting power. I worked out of the country for four months and it ran my battery down. A simple jump and short drive got the battery back up to normally. That wouldn’t have been an issue if I had been driving my vehicle.
thisisnotmyname Avatar
78 months ago
Are you charging while your car is off? I think someone is feeding you a line. Your alternator tends to put out about 14V unless you are constantly at low idle (and even then enough voltage not to matter for these purposes) and probably 85 amps or so (maybe less on your specific car but again not enough to matter for these purposes). So 14v * 85a = 1190w, 15w of draw is meaningless.
Even if the vehicle is off, unless you were routinely drawing the battery very low or killing it (which would be very unlikely even at max 15w draw of that charger) it shouldn't have affected battery life. If the car was running it should never have hit the battery at all.
edit to add: for comparison your starter motor probably draws hundreds of amps when you start your car (run continuously those motors are probably around 1kw) and that's pure battery. Granted much shorter period but its disingenuous for the dealer to be concerned about your 15w draw (only while a device is connected and needing full speed charging) vs 1kw plus of starter motor draw. It doesn't add up.
edit to add more: you should ask them if they are concerned about the likely 50w+ car stereo (although I won't go into all the ways that car stereo power is mis-rated) installed by the factory
Popular Stories
ios 19 messages app
Apple Sues Jon Prosser Over iOS 26 Leaks
Thursday July 17, 2025 8:40 pm PDT by
Earlier this year, YouTuber Jon Prosser shared multiple videos showing off what he claimed to be re-created renderings of what was then presumed to be called iOS 19 and which was eventually unveiled by Apple as iOS 26 at WWDC in June. In his first video back in January, Prosser showed off a Camera app redesign with a simpler set of buttons for moving between photo and video modes, and he...
iPhone 17 Colors
All 15 New iPhone 17 and iPhone 17 Pro Colors Revealed in Latest Leak
Wednesday July 16, 2025 6:50 am PDT by
We may finally have a definitive list of all color options for the iPhone 17 series, ahead of the devices launching in September. MacRumors concept In a report for Macworld today, Filipe Espósito said he obtained an "internal document" that allegedly reveals all of the color options for the upcoming iPhone 17, iPhone 17 Air, iPhone 17 Pro, and iPhone 17 Pro Max models. The report includes ...
iOS 26 on Three iPhones
Here's When to Expect the iOS 26 Public Beta
Tuesday July 15, 2025 11:07 am PDT by
Apple previously announced that a public beta of iOS 26 would be available in July, and now a more specific timeframe has surfaced. Bloomberg's Mark Gurman today said that Apple's public betas should be released on or around Wednesday, July 23. In other words, expect the public betas of iOS 26, iPadOS 26, macOS 26, and more to be available at some point next week. Apple will be releasing...
iPhone 17 Pro Dark Blue and Orange
Ranked: The Best Features Rumored for the iPhone 17 Lineup
Wednesday July 16, 2025 4:17 pm PDT by
We have just under two months to go until the debut of Apple's iPhone 17 models, and rumors have been ramping up in recent weeks. We went through everything we know so far, pulling out the most exciting rumors and highlighting some other changes that aren't going to be so great. Top Tier Ultra Thin iPhone 17 Air - The iPhone 17 Air is 2025's most exciting iPhone rumor, because it's the...
Foldable iPhone's Thickness and Price Range Detailed in New Reports
Wednesday July 16, 2025 11:31 am PDT by
Apple's long-rumored foldable iPhone will likely have a starting price between $1,800 and $2,000 in the U.S., analysts at investment banking firm UBS said this week. If so, the foldable iPhone would cost more than a MacBook Pro, which starts at $1,599. With a starting price of at least $1,800, the foldable iPhone would be the most expensive iPhone model ever released, topping the Pro Max at...
iPhone 17 Pro in Hand Feature Lowgo
iPhone 17 Pro Coming Soon With These 16 New Features
Friday July 11, 2025 12:40 pm PDT by
Apple's next-generation iPhone 17 Pro and iPhone 17 Pro Max are only two months away, and there are plenty of rumors about the devices. Below, we recap key changes rumored for the iPhone 17 Pro models. Latest Rumors These rumors surfaced in June and July:A redesigned Dynamic Island: It has been rumored that all iPhone 17 models will have a redesigned Dynamic Island interface — it might ...
Apple Watch Ultra 2 Complications
Apple Watch Ultra 3: What to Expect
Sunday July 13, 2025 10:30 am PDT by
The long wait for an Apple Watch Ultra 3 is nearly over, and a handful of new features and changes have been rumored for the device. Below, we recap what to expect from the Apple Watch Ultra 3:Satellite connectivity for sending and receiving text messages when Wi-Fi and cellular coverage is unavailable 5G support, up from LTE on the Apple Watch Ultra 2 Likely a wide-angle OLED display that ...
