iPhone 17 Pro vs. iPhone 17 Pro Max: What's Exclusive to Apple's Largest Flagship iPhone - MacRumors
Skip to Content
Before Apple unveiled the iPhone 17 Pro and ‌iPhone 17 Pro‌ Max, there were rumors suggesting that some features like the upgraded Telephoto camera could be exclusive to the Pro Max. In the past, Apple has limited some capabilities to the Pro Max, so it was a possibility, but the two devices have the same general feature set this year.
iphone 17 pro orange
There are a few things that are different, of course, but that comes down to size.
Display
The ‌iPhone 17 Pro‌ Max has a 6.9-inch display, while the ‌iPhone 17 Pro‌ has a smaller 6.3-inch display. The ‌iPhone 17 Pro‌ is smaller and lighter weight than the Pro Max, and easier to use one-handed.
Battery
Since there's more room in the ‌iPhone 17 Pro‌ Max for the battery, it lasts longer. The ‌iPhone 17 Pro‌ offers up to 33 hours of video playback, while the ‌iPhone 17 Pro‌ Max offers up to 39 hours of video playback. It's the longest battery life in an iPhone to date.
Storage
With the ‌iPhone 17 Pro‌ Max, you can get up to 2TB of storage, which is a new upper limit for the iPhone. The ‌iPhone 17 Pro‌ is limited to 1TB. The difference may be due to size and the space inside for storage components.
The 2TB ‌iPhone 17 Pro‌ Max costs $2,000.
There are no other differences between the ‌iPhone 17 Pro‌ and the ‌iPhone 17 Pro‌ Max, so if you opt for the smaller Pro model, you're only missing out on a larger display size, a longer battery, and the option to upgrade to 2TB of storage.
The ‌iPhone 17 Pro‌ models will be available for pre-order this Friday.
Related Roundup: iPhone 17 Pro
Related Forum: iPhone
Popular Stories
iOS 26
iOS 26.4 Adds Two New Features to CarPlay
Tuesday March 24, 2026 1:55 pm PDT by
iOS 26.4 was released today, and it includes a couple of new features for CarPlay: an Ambient Music widget and support for voice-based chatbot apps. To update your iPhone 11 or newer to iOS 26.4, open the Settings app and tap on General → Software Update. CarPlay will automatically offer the new features so long as the iPhone connected to your vehicle is running iOS 26.4 or later....
AirPods Pro Firmware Feature
Apple Releases New Firmware for AirPods Pro 3, AirPods Pro 2 and AirPods 4
Tuesday March 24, 2026 12:31 pm PDT by
Apple today released new firmware for the AirPods Pro 2, AirPods Pro 3, and the AirPods 4. The firmware has a version number of 8B39, up from 8B34 on the AirPods Pro 3, 8B28 on the AirPods Pro 2, and 8B21 on the AirPods 4. There is no word on what's included in the firmware, but Apple has a support document with limited notes. Most updates are limited to bug fixes and performance...
apple tv 4k new orange
tvOS 26.4 Adds These New Features to Your Apple TV
Wednesday March 25, 2026 3:33 pm PDT by
Apple this week released tvOS 26.4, and the software update includes a handful of new features and changes for the Apple TV. tvOS 26.4 is compatible with all Apple TV 4K and Apple TV HD models released since 2015. To update your Apple TV, open the Settings app on the device, navigate to System → Software Updates, and select Update Software. Below, we have recapped what is new in tvOS...
Top Rated Comments
sniffies Avatar
7 months ago
Also, the word Max is exclusive.
Score: 32 Votes (Like | Disagree)
AusMness Avatar
7 months ago
As a small Pro user I see this as an absolute win
Score: 23 Votes (Like | Disagree)
klasma Avatar
7 months ago
Why did they make the larger display exclusive to the Pro Max? :(
Score: 20 Votes (Like | Disagree)
ProbablyDylan Avatar
7 months ago
Bigger phone is bigger. Consider my awe dropped. 🙄
Score: 16 Votes (Like | Disagree)
Andres Cantu Avatar
7 months ago
I had mentioned before how I would skip the upgrade if they pulled another 12 Pro Max or 15 Pro Max and gave the better camera to the larger model only. I'm glad they didn't, so will be upgrading from 15 Pro.
If the pattern continues, the 18 Pro Max will get that cool new rumored variable aperture feature, while the 18 Pro will skip it until they "magically" find a way to fit in in the 19 Pro.
Score: 11 Votes (Like | Disagree)
7 months ago
That PRO font sure is chonky.
