Samsung's Headset to Offer Better Displays Than Apple Vision Pro - MacRumors
Skip to Content
Samsung's upcoming AR/VR headset will feature more advanced displays than Apple's Vision Pro, according to a new supply chain report from The Elec that reveals key specifications and sourcing strategies.
samsung headset 2
Samsung is preparing to launch its first extended reality (XR) headset later in 2025, and it will reportedly contain displays that surpass the resolution of Apple's Vision Pro. The Elec claims that the device will use 1.3-inch OLEDoS (OLED on Silicon) microdisplays with a pixel density of approximately 3,800 pixels per inch (PPI).
In comparison, the Vision Pro uses 1.42-inch OLEDoS panels from Sony with a pixel density of 3,391 PPI. The increase in pixel density will likely represent a significant improvement in visual clarity over the Vision Pro. Despite having a slightly smaller panel, which could reduce the field of view, Samsung's headset should be able to deliver sharper visuals.
The Vision Pro was the first mainstream consumer device to adopt OLEDoS microdisplays. OLEDoS technology allows for extremely high resolution in compact form factors, making it particularly suitable for immersive virtual reality applications.
Samsung is apparently reviewing plans to source OLEDoS panels from both Sony and Samsung Display, with Sony currently acting as the main supplier. While Sony is recognized for its expertise in microdisplay manufacturing, it has limited its production capacity and previously declined Apple's request to expand output for the Vision Pro. Sony's focus remains centered on its entertainment business, and it is reportedly cautious about committing additional resources to its display operations.
Popular Stories
iphone duo hero
Samsung Mocks iPhone Duo
Wednesday September 9, 2026 1:28 pm PDT by
Samsung took to social media today to mock the iPhone Duo while Apple announced the device. In a series of sarcastic posts that did not explicitly mention Apple or the iPhone Duo, Samsung made comments like "Let us know when you're done reheating our leftovers" and "Was it exciting? No. Did it happen? Yes." Samsung used an #ItsTimeToSwitch hashtag in some of its posts. Launching on...
iphone duo hero
iPhone Duo is Dust-Tight With IP68 Rating, Unlike Samsung's Galaxy Z Fold8
Wednesday September 9, 2026 5:46 pm PDT by
The iPhone Duo has an IP68 dust and water resistance rating, beating Samsung and tying Google. Samsung's latest Galaxy Z Fold8 models have an IP48 dust and water resistance rating, which means they aren't able to hold up to dust as well. Google's Pixel 11 Pro Fold also has an IP68 rating. IP6X for dust means the iPhone Duo is "dust-tight" and no dust is able to get in. The IPX8 rating for ...
Low Angle iPhone Purple
iPhone 18 Pro: Apple Secures Lower Display Prices Amid RAM Shortage
Wednesday August 12, 2026 9:43 am PDT by
Apple has secured lower prices for OLED displays for the upcoming iPhone 18 Pro models, according to industry sources cited by South Korea's DealSite. For example, the report said Apple will pay LG and Samsung around $68 per OLED display destined for the iPhone 18 Pro Max, down significantly from the $110 to $120 that it paid those suppliers for each iPhone 17 Pro Max display. Apple is...
Top Rated Comments
16 months ago
I mean … if you’re trying to build a device to compete with the headset Apple announced two years ago and launched a year and a half ago, I should hope that the one today would have better technology. 🤷🏻‍♂️ And is probably significantly less expensive.
Score: 34 Votes (Like | Disagree)
16 months ago
Folks, Apple seeks to be the best, not the first, in skating to where the puck will be. The Apple Vision Pro is the best-in-class device for ushering-in the era of spatial computing. Everybody recognizes the Apple Vision Pro is a beta product for early adopters to try tomorrow's technology, today. So, Apple has already arrived to where the puck will be and when the technology catches up, watch out, because the ALL NEW Vision Pro will truly be a game changer for ultra pros!
Score: 28 Votes (Like | Disagree)
JohnRckr Avatar
16 months ago
I’m not sure if you’re trolling right now or not..
I really don’t know.
Score: 15 Votes (Like | Disagree)
16 months ago
I am skeptical that this will make any difference at all really. Once you reach a certain pixel density, it doesn't make a difference going beyond that.
Higher display density is the last thing on my priority list.
The things that would make the biggest difference is better lenses, wider field of view, and better passthrough video quality. And it sounds like, unless they've got some fancy lenses that can compensate for this, they will have a worse field of view because they'll have smaller displays.
Things that matter
- Better passthrough quality, which is more limited by the camera specs than the display specs. Apple Vision Pro rendered content is really sharp and clear.
- Better lenses because around the peripheral vision the actual glass curvature distorts my vision and so a lot of the things I can see are not really usable because they are out of focus.
- wider field in view in general to be seeing less black blinders to feel more immersed and see more of my surroundings.
Score: 14 Votes (Like | Disagree)
16 months ago
wow, the device from 2025 still apparently being finalized has newer technology than the one announced in 2023 and likely finalized in 2022?
Color me shocked.
also, I could be wrong here, but one of the highly criticized part of the Apple Vision Pro was the FOV not being big enough, and it sounds like these Samsung headsets will have… An even smaller FOV.
as someone who can’t even interpret visual content, I don’t care, but in my brain, I feel like higher resolution but smaller FOV is going to lead to a worse experience.
Score: 12 Votes (Like | Disagree)
jarman92 Avatar
16 months ago
Not sure a ~12% increase in PPI can reasonably be called a "significant improvement in visual clarity."
