iPad Air 2022 vs. iPad Pro 2021 Buyer's Guide
In March 2022, Apple introduced the fifth-generation iPad Air, featuring the M1 chip, 5G connectivity, and a new front-facing camera system. The updated iPad Air comes almost a year after in Apple introduced its current iPad Pro lineup, which also features the ‌M1‌ chip and 5G connectivity, but sports a number of high-end features like ProMotion and a Thunderbolt port.
ipad pro vs air early 2022
The introduction of the previous, fourth-generation ‌iPad Air‌ in September 2020 brought the device much closer to the ‌iPad Pro‌ in terms of design, and with the latest model, the ‌iPad Air‌ has gained the same ‌M1‌ chip as the ‌iPad Pro‌, bringing them even closer together. Despite this, the ‌iPad Air‌ and ‌iPad Pro‌ are still quite different devices intended for different groups of users.
Should you consider purchasing the ‌iPad Air‌ to save money, or do you need the high-end features of the ‌iPad Pro‌? Our guide answers the question of how to decide which of these two iPads is best for you.
Comparing the iPad Air and iPad Pro
The ‌iPad Air‌ and ‌iPad Pro‌ share a large number of key features, such as a squared-off industrial design, a 12MP rear Wide camera, a 12MP front-facing Ultra Wide camera, and a USB-C port:
Similarities
  • Industrial design with flat edges
  • Liquid Retina display with 264 ppi, full lamination, oleophobic and anti-reflective coating, P3 Wide Color, and True Tone
  • ‌M1‌ chip with next-generation Neural Engine
  • 5G connectivity
  • ƒ/1.8 12MP Wide rear camera, with digital zoom up to 5x and Smart HDR 3 for photos
  • ƒ/2.4 12MP front-facing Ultra Wide camera with 2x optical zoom out and Center Stage
  • 4K video recording at 24 fps, 25 fps, 30 fps, or 60 fps, 1080p HD video recording at 25 fps, 30 fps or 60 fps, Extended dynamic range for video up to 30 fps, 3x video zoom, slo-mo video support for 1080p at 120 fps or 240 fps, time-lapse video with stabilization
  • "All-day" 10 hour battery life
  • Wi‑Fi 6 and Bluetooth 5.0 connectivity
  • USB‑C connector
  • Compatible with Magic Keyboard, Smart Keyboard Folio, and Apple Pencil (2nd generation)
Apple's specification breakdown shows that the two iPads share many of their most important features, not least the ‌M1‌ chip. Even so, there are an even larger number of meaningful differences between the ‌iPad Air‌ and ‌iPad Pro‌ that are worth highlighting, including their displays, authentication technologies, and rear camera setups.
Differences
iPad Air
  • Touch ID built into the top button
  • 10.9-inch display
  • Liquid Retina LED display
  • 500 nits max brightness (typical)
  • 8GB of memory
  • Sub-6GHz 5G connectivity
  • Digital zoom up to 5x
  • 3x video zoom
  • ƒ/2.4 12MP Ultra Wide front camera with 2x optical zoom out and Center Stage
  • Two speaker audio landscape mode
  • USB‑C connector
  • Up to 256GB storage
  • Available in Space Gray, Starlight, Pink, Purple, and Blue
  • Price starting at $599
iPad Pro
  • Face ID enabled by TrueDepth camera
  • 11-inch or 12.9-inch display, with 120Hz ProMotion technology
  • Liquid Retina XDR mini-LED display on 12.9-inch model with 1,000 nits max full-screen brightness and 1,600 nits peak brightness (HDR)
  • 600 nits max brightness (typical)
  • 8GB or 16GB of memory
  • Sub-6GHz and mmWave 5G connectivity
  • ƒ/1.8 12MP Wide and ƒ/2.4 10MP Ultra Wide rear cameras with LiDAR scanner
  • True Tone flash
  • Digital zoom up to 5x and 2x optical zoom out
  • Video zoom up to 3x and 2x optical zoom out
  • Extended dynamic range for video up to 30 fps
  • Audio zoom
  • ƒ/2.4 12MP TrueDepth Ultra Wide front camera with 2x optical zoom out, Center Stage, Portrait Mode, and Portrait Lighting, Animoji, and Memoji
  • Stereo recording
  • Four-speaker audio
  • USB‑C connector with support for Thunderbolt / USB 4
  • Up to 2TB storage
  • Available in Silver and Space Gray
  • Price starting at $799
Read on for a closer look at each of these aspects, and see what exactly both iPads have to offer.
Design
Both the ‌iPad Air‌ and the ‌iPad Pro‌ use Apple's most recent product design language, also seen on the iPhone 12 and iPhone 13 lineup, the iPad mini, and the iMac, featuring industrial squared-off edges.
m1 ipad pro
The 10.9-inch ‌iPad Air‌ is almost exactly the same size as the 11-inch ‌iPad Pro‌, despite having a smaller display, resulting in it having slightly thicker bezels.
Although the design of the two iPad models is similar, the ‌iPad Air‌ is available in a wider range of colors. The ‌iPad Air‌ is available in Space Gray, Starlight, Pink, Purple, and Blue, while the ‌iPad Pro‌ is only available in Silver and Space Gray.
Authentication
A key area of difference between the ‌iPad Air‌ and ‌iPad Pro‌ is authentication. The ‌iPad Air‌ features ‌Touch ID‌, while the ‌iPad Pro‌ features ‌Face ID‌.
ipad air touch id
The ‌iPad Air‌ has a ‌Touch ID‌ fingerprint scanner embedded in the ‌iPad‌'s top button. The ‌iPad Pro‌'s ‌Face ID‌ is facilitated by the TrueDepth camera array in the top bezel.
new ipad pro 11 inch
Unlocking is something that may be used dozens of times every day, so it is important to choose your preferred method of authentication if you feel particularly strongly about it. That being said, both ‌Touch ID‌ and ‌Face ID‌ are now extremely refined technologies that work well, and most users will likely be happy with whichever they have.
Displays
Display Sizes
The ‌iPad Air‌ features a 10.9-inch display, while the ‌iPad Pro‌ has the option of either an 11-inch display or a 12.9-inch display.
ipad air ipad pro display sizes
The difference in screen size between the 10.9-inch ‌iPad Air‌ and the 11-inch ‌iPad Pro‌ is virtually negligible. These models are around half a pound lighter than the 12.9-inch ‌iPad Pro‌ and will be best for users focused on portability and easy handheld use.
The 12.9-inch ‌iPad Pro‌, on the other hand, is best for users who are intending to use their ‌iPad‌ more like a laptop, likely on a table or with a keyboard accessory such as the Magic Keyboard. In particular, multitasking is a much better experience on the 12.9-inch ‌iPad Pro‌'s large display.
m1 ipad pro table
Display Technologies
Both the ‌iPad Air‌ and the 11-inch ‌iPad Pro‌ feature Liquid Retina LED displays with 264 ppi, full lamination, an oleophobic and anti-reflective coating, P3 Wide Color, and True Tone.
The 11-inch ‌iPad Pro‌ can get 100 nits brighter than the ‌iPad Air‌ and features ProMotion technology for up to 120Hz refresh rates.
m1 ipad pro display
The biggest advancement in display technology comes to the 12.9-inch ‌iPad Pro‌. This model has all of the display features included with its smaller sibling, including 120Hz ProMotion, but uses a fundamentally different underlying display technology: mini-LED.
Apple calls the 12.9-inch ‌iPad Pro‌'s mini-LED screen a "Liquid Retina XDR display." Mini-LED allows the 12.9-inch ‌iPad Pro‌ to reach up to 1,000 nits full-screen brightness, 1,600 nits peak brightness, and a 1 million-to-1 contrast ratio. The display can reflect what can be seen in the real world by capturing the brightest highlights and subtle details in even the darkest images, allowing users to view and edit true-to-life HDR and Dolby Vision content, which is especially important to creative professionals, including photographers, videographers, and filmmakers.
The ‌iPad Air‌'s Liquid Retina display will be sufficient for the vast majority of users, but some may prefer the responsiveness of ProMotion of the ‌iPad Pro‌ for tasks such as gaming. The 12.9-inch ‌iPad Pro‌'s high-end Liquid Retina XDR display, on the other hand, is best for users who consume a lot of HDR content, those who are creative professionals, or those who want the best possible display.
Storage
The ‌iPad Air‌ offers the option of either 64GB or 256GB storage, while the ‌iPad Pro‌ offers 128GB, 256GB, 512GB, 1TB, or 2TB. The maximum 256GB of storage in the ‌iPad Air‌ will be enough for many users, but for those power users who intend to store a large amount of data on their ‌iPad‌, the option is available with the ‌iPad Pro‌.
Memory
The ‌iPad Air‌ has 8GB of RAM, while the ‌iPad Pro‌ has either 8GB or 16GB, depending on which storage configuration you choose. ‌iPad Pro‌ configurations with either 1TB or 2TB of storage contain 16GB of RAM, while all other storage configurations contain 8GB of RAM.
8GB in the ‌iPad Air‌ will be adequate for casual users, but 8GB will be defter at handling multiple windows of the same application and a range of intense background tasks.
Ultimately, iPadOS is excellent at memory management and it is questionable how far apps can take advantage of extra memory, so it is unlikely that the amount of RAM in your ‌iPad‌ will be important in most cases.
Cameras
Rear Cameras
A major area of difference between the two ‌iPad‌ models is their camera setups. The ‌iPad Air‌ features a single ƒ/1.8 12MP Wide camera. The ‌iPad Pro‌ has the same ƒ/1.8 12MP Wide camera as the ‌iPad Air‌, but also adds a ƒ/2.4 10MP Ultra Wide camera and a LiDAR scanner.
iPad Air camera
As well as being able to zoom in digitally five times, the ‌iPad Pro‌ can also optically zoom out up to two times, thanks to its Ultra Wide lens. The ‌iPad Pro‌ has extended dynamic range when recording video up to 30 fps, and also features a True Tone flash.
ipadprocameras
LiDAR allows the ‌iPad Pro‌ to measure the distance to surrounding objects up to five meters away, operating at the photon level at nano-second speed. This makes the ‌iPad Pro‌ capable of a "new class" of improved AR experiences with better motion capture, understanding of the environment, and people occlusion.
m1 ipad pro ar
Users who like to use their ‌iPad‌ as a large viewfinder for photography or heavy users of AR will appreciate the ‌iPad Pro‌'s more advanced camera setup, but for the majority of users who do not use the ‌iPad‌'s rear camera very often, the ‌iPad Air‌'s single Wide camera is more than good enough.
Front-Facing Cameras
Both the ‌iPad Air‌ and the ‌iPad Pro‌ have a ƒ/2.4 12MP Ultra Wide front-facing camera with 2x optical zoom out. The ‌iPad Pro‌'s TrueDepth camera also enables Portrait mode, and Portrait Lighting, Animoji, and Memoji.
Both devices offer "Center Stage" for video calls with the front-facing camera. Center Stage uses the ‌iPad‌'s larger field of view on the machine learning capabilities of ‌M1‌ to recognize and keep users centered in the frame. As users move around, Center Stage automatically pans to keep them in the shot. When others join in, the camera detects them too, and smoothly zooms out to fit everyone into the view.
Other than Portrait mode, and Portrait Lighting, Animoji, and Memoji, the two front-facing camera setups are identical and there is no reason to get one over the other.
Speakers and Microphones
The ‌iPad Air‌ has two-speaker audio in landscape mode, while the ‌iPad Pro‌ has wider four-speaker audio. If you use your ‌iPad‌ for consuming lots of music and videos with the built-in speakers, the ‌iPad Pro‌ will deliver a slightly better experience.
The ‌iPad Pro‌ can record audio in stereo and features "studio-quality" mics, which may be important for some users who record music or lectures using their ‌iPad‌. Even so, the ‌iPad Air‌ has a proficient speaker and microphone setup that will be sufficient for most users.
Wireless Connectivity
In terms of wireless connectivity, both iPads feature Wi-Fi 6, Bluetooth 5.0, and 5G on cellular models. The ‌iPad Air‌ only supports a sub-6GHz 5G cellular connection, while the ‌iPad Pro‌ supports both sub-6GHz and mmWave 5G in the United States. mmWave 5G is considerably faster than sub-6GHz where available. If you need a high-speed 5G cellular connection in the United States, this may be a good reason to invest in the ‌iPad Pro‌.
Ports
The ‌iPad Air‌ features a standard USB-C port, while the ‌iPad Pro‌ features a Thunderbolt port. USB-C on the ‌iPad Air‌ can transfer at a speed of 10Gb/s, while Thunderbolt supports speeds of up to 40Gb/s. As well as being considerably faster, Thunderbolt opens up the potential for compatibility with a much broader range of Thunderbolt-only accessories such as external hard drives and monitors. Thunderbolt also is backward-compatible with USB-C, so the two ports look identical.
iPad Pro USB C Feature Purple Cyan
Even though Thunderbolt is much faster than the ‌iPad Air‌'s standard USB-C port, most users likely do not have Thunderbolt accessories that can take advantage of these speeds. For this reason, the ‌iPad Air‌ is again the best option for most people in terms of port options.
Accessories
Both the ‌iPad Air‌ and ‌iPad Pro‌ support accessories such as the ‌Apple Pencil‌ 2, as well as Apple's ‌Smart Keyboard‌ Folio and Magic Keyboard. Since they both support the same accessories, there is no reason to buy one model over the other when it comes to the likes of keyboards or trackpads.
ipad pro
Nevertheless, it should be considered that accessories such as the ‌Apple Pencil‌ and Magic Keyboard have to be purchased separately from the ‌iPad‌, so will push up the overall price. Therefore, if the ‌iPad Pro‌, which starts at $799 for the 64GB 11-inch model, is already moving out of your price range and you want an accessory such as the $299 Magic Keyboard, you may need to opt for the ‌iPad Air‌, which starts at $599, to bring down the overall cost.
Other iPad Options
If the ‌iPad Air‌ is too expensive at $599, you may want to consider the eighth-generation ‌iPad‌, which has a much lower price tag of $329. This ‌iPad‌ has a 10.2-inch display, the A13 Bionic chip, Center Stage, and is compatible with accessories such as the Apple ‌Smart Keyboard‌ and the first-generation ‌Apple Pencil‌.
f1600191751
While it lacks the all-screen design of the ‌iPad Air‌, USB-C, and 4K video recording, the eighth-generation ‌iPad‌ is an excellent low-cost alternative to the mid to high-end iPads.
ipad mini 6 lineup
Moreover, if you are looking for the smallest, most portable ‌iPad‌, you should consider the ‌iPad mini‌, which features a smaller 8.3-inch display and the A15 chip, for $499.
Final Thoughts
Overall, the ‌iPad Air‌ is the better option for the majority of users, simply on the basis of value for money. For most people, the additional $200+ needed to buy the ‌iPad Pro‌ will not be justified to get the likes of ‌Face ID‌, a more versatile rear camera system, four-speaker audio, and a ProMotion display with refresh rates up to 120Hz.
Some ‌iPad Pro‌ features, such as LiDAR, the Ultra Wide rear camera, larger storage options and up to 16GB of memory, and Thunderbolt connectivity, will only be practically useful to a small niche of ‌iPad‌ users. Most users will never use some of these high-end features. Indeed, many features such as the True Tone flash, mmWave 5G connectivity, Audio zoom, and stereo audio recording may not be meaningfully utilized by many users.
Professionals who have a clear use case for needing larger amounts of RAM and storage, Thunderbolt connectivity, and mini-LED for HDR content will benefit from buying the ‌iPad Pro‌. Prosumers will also enjoy features such as 120Hz ProMotion for smoother scrolling and gaming, deeper blacks and more vivid colors with the mini-LED display, and LiDAR for AR experiences, even if they are not necessary, and those who want a larger 12.9-inch display for content consumption will similarly need to go with the higher-end ‌iPad Pro‌ model.
Prosumers and professionals who want the ‌iPad‌ to replace their laptop or computer should likely choose the 12.9-inch ‌iPad Pro‌ if they are pairing it with the Magic Keyboard due to the added screen space for multiple applications. This larger ‌iPad Pro‌ is considerably different to the ‌iPad Air‌, setting itself apart with mini-LED and a much larger display.
Beyond these individual circumstances, the ‌iPad Air‌ is the best option and will be more than ample for most users' needs. With the ‌iPad Air‌, users can get an all-screen design, the ‌M1‌ chip, practical features like USB-C and 5G connectivity, and compatibility with the latest Apple accessories.
Related Roundups: iPad Air , iPad Pro
Related Forum: iPad
Top Rated Comments
GuruZac Avatar
28 months ago
Basically, if you don’t want the larger 12.9 display, and never had ProMOTION, the iPad Air is the way to go. However, at $749 for the 256GB Air, you are much better off going with the 11” iPad Pro. For $50 more you get a better display, FaceID, quad speakers, faster thunderbolt port, cameras/LiDAR. ProMOTION alone is worth it. If you want a bigger display, well, there’s only one option now.
On a separate note, I think it’s time Apple changes the naming of the iPads. The Air used to mean something, now it doesn’t.
Score: 28 Votes (Like | Disagree)
erikkfi Avatar
28 months ago
The two storage tiers on the Air ruin the whole iPad shopping experience for me. First I look at the 64GB Air, then talk myself up to the 128GB Pro, then realize I started at $599 and am now looking at $1000 after taxes. Then do you know what I do? I buy nothing, and decide to make my current iPad last through yet another refresh cycle.
gaximus Avatar
28 months ago
Pro Motion = 120Hz display, believe me it's not that great for creation needs outside video editing.
Considering almost all video is at 60hz or less, I'd say video editing is the only thing that doesn't need 120hz. Scrolling, gaming, Apple Penciling, opening apps, etc. are all better with 120hz
julesme Avatar
28 months ago
"For most people, the additional $200+ needed to buy the iPad Pro will not be justified..."
This is misleading. It's an extra $150 when you compare the 256 GB version ($749 vs $899). The Air also doesn't offer a 128GB capacity model at all, so the entry level $200 difference compares a 64GB Air to a 128GB Pro.
(Edit: I initially got the specs wrong).
nutmac Avatar
28 months ago
If you can get by with 64GB, choose iPad Air ($599).
If 128GB is your sweet spot and you prefer Face ID over Touch ID, choose 11-inch iPad Pro ($799) as it's only $50 more than 256GB iPad Air. And you get Thunderbolt, better speakers, brighter display, and ultrawide camera lens with LiDAR.
If you need 256GB, you can spend $150 more for iPad Pro ($899). If you prefer Touch ID, get iPad Air ($749).
I suspect the next update to 11-inch iPad Pro will gain XDR, which is what I would personally wait for.
telo123 Avatar
28 months ago
It is. I’ve had the budget iPad with Apple Pencil and the iPad Pro with Apple Pencil. The level of smoothness I felt when I wrote on the iPad Pro for the first time had me never look back and never regretted the purchase. Scrolling and everything is just cool. Even now, if I went back to the budget iPad (I gave to family), it feels … not smooth.
On another note, I still believe the iPad Pro is the better device. The 120 Hz, the speakers (still amazes me btw when it gets to max volume and it still remains clear and bright), and x2 the storage when strictly comparing the base model for each are all good reasons for the $200 difference.
Popular Stories
ipad pro 2022
Apple Event Rumors: iPad Pro With M4 Chip and New Apple Pencil With Haptic Feedback
Sunday April 28, 2024 6:19 am PDT by
In his Power On newsletter today, Bloomberg's Mark Gurman outlined some of the new products he expects Apple to announce at its "Let Loose" event on May 7. First, Gurman now believes there is a "strong possibility" that the upcoming iPad Pro models will be equipped with Apple's next-generation M4 chip, rather than the M3 chip that debuted in the MacBook Pro and iMac six months ago. He said a ...
iOS 18 General Notes Feature 2
iOS 18 Rumored to 'Overhaul' Notes, Mail, Photos, and Fitness Apps
Sunday April 28, 2024 6:44 am PDT by
Bloomberg's Mark Gurman today said that iOS 18 will "overhaul" many of Apple's built-in apps, including Notes, Mail, Photos, and Fitness. Gurman did not reveal any specific new features planned for these apps. It was previously rumored that the Notes app will gain support for displaying more math equations, and a built-in option to record voice memos, but this is the first time we have...
iPad Pro OLED Feature 2
Apple to Use 'Best OLED Panels on the Market' for Upcoming iPad Pro
Monday April 29, 2024 10:04 am PDT by
Apple's upcoming iPad Pro models will feature "by far the best OLED tablet panels on the market," according to Display Supply Chain Consultants. Set to be announced on May 7, the OLED iPad Pro models will feature LTPO (a more power efficient form of OLED), a 120Hz ProMotion refresh rate, and a tandem stack and glass thinning that will bring "ultra-thin and light displays" that support high...
maxresdefault
Apple Announces 'Let Loose' Event on May 7 Amid Rumors of New iPads
Tuesday April 23, 2024 7:11 am PDT by
Apple has announced it will be holding a special event on Tuesday, May 7 at 7 a.m. Pacific Time (10 a.m. Eastern Time), with a live stream to be available on Apple.com and on YouTube as usual. The event invitation has a tagline of "Let Loose" and shows an artistic render of an Apple Pencil, suggesting that iPads will be a focus of the event. Subscribe to the MacRumors YouTube channel for more ...
iOS 18 Siri Integrated Feature
iOS 18 Rumored to Add These 10 New Features to Your iPhone
Wednesday April 24, 2024 2:05 pm PDT by
Apple is set to unveil iOS 18 during its WWDC keynote on June 10, so the software update is a little over six weeks away from being announced. Below, we recap rumored features and changes planned for the iPhone with iOS 18. iOS 18 will reportedly be the "biggest" update in the iPhone's history, with new ChatGPT-inspired generative AI features, a more customizable Home Screen, and much more....
top stories 27apr2024
Top Stories: Apple Announces 'Let Loose' Event With New iPads and More Expected
Saturday April 27, 2024 6:00 am PDT by
New iPads are coming, and Apple is holding a virtual event to introduce them! While it appears likely to be a relatively short video event, we should be seeing new iPad Pro and iPad Air models, some new accessories, and perhaps some additional surprises. Other Apple news and rumors this week included word that Apple is FINALLY planning to introduce a native Calculator app for the iPad later...
