How to Optimize Battery Charging in iOS 13
Thursday July 25, 2019 4:56 PM PDT by Tim Hardwick
iPhone battery health became a hot topic in 2018, after Apple was found to be quietly throttling the processor speeds of iOS devices that have degraded batteries to prolong their life as long as possible.
Apple responded to concerns about this background behavior by issuing a software update for iOS 11 that introduced a Battery Health feature, providing more information about the state of a device's battery and whether or not it is impacting performance.
Since then, Apple has added a new option to its Battery Health feature called "Optimized Battery Charging," which is designed to extend the total battery life of a device running iOS 13. When enabled, this option learns from your personal device habits and waits to finish charging all the way up until you need your ‌iPhone‌.
The way it works makes a lot of sense in practice. For example, if you regularly charge your ‌iPhone‌ up at night while you're asleep, the device may opt to limit its charging to the 80 percent mark, and then wait for an hour or so before you wake up to charge the remaining 20 percent. This keeps the ‌iPhone‌ at an optimal capacity for battery health by reducing the amount of time that it's sat on the charger at 100 percent charged, which can reduce its life over time.
To turn on the new Optimized Battery Charging option, launch the Settings app on your ‌iPhone‌ or iPad, then scroll down and tap Battery. On the next screen, select Battery Health, and then toggle the switch next to Optimized Battery Charging to the green ON position.
battery
Note that the Battery Health screen contains useful additional information about the status of your device's battery, which you can use to decide if it needs replacing.
Peak Performance Capability indicates that the battery on our device supports peak performance, so we shouldn't experience any kind of throttling during general usage.
Check this status to see if a degraded battery has resulted in performance slowdowns. Keep in mind that throttling doesn't kick in until the battery becomes severely degraded and can no longer offer enough power to support spikes in processor usage.
If you have a bad battery, it will say "Your battery's health is significantly degraded," and it will let you know that an Apple Authorized Service Provider can replace the battery to restore full performance. If an unexpected shutdown shutdown occurs, performance management is turned on automatically. Note, however, that a small Disable option will appear when this happens. If you tap it, you'll be given the option to disable performance management.
Elsewhere on the Battery Health screen, Maximum Capacity gives you a measure of battery capacity compared to when your battery was brand new. If the maximum capacity percentage falls, you'll likely get less usage out of your device between charges. In other words, it's an indicator of how your battery is performing overall and directly correlates with how long your ‌iPhone‌ will last on a single charge.
Related Roundups: iOS 13, iPadOS
Top Stories
Apple Sending Replacement AirPods With Unreleased Firmware, Rendering Them Unusable
Wednesday April 8, 2020 9:23 am PDT by Juli Clover
Customers who require a replacement AirPod from Apple have in some cases been receiving an AirPod running 2D3 firmware, which is not a version of the AirPods firmware that's been publicly released. As described on the MacRumors forum and Reddit (via iMore), customers who get an AirPod with the 2D3 firmware are unable to pair it with the existing unreplaced AirPod, leaving the AirPods unable...
Facebook Launches 'Tuned' Messaging App for Couples
Wednesday April 8, 2020 4:50 am PDT by Tim Hardwick
Facebook has quietly released Tuned, a new messaging app designed to provide a "private space" for couples to connect, reports The Information. Designed by NPE, an experimental group within the company that was established last year, the app encourages couples to share messages, notes, cards, voice memos, photos and Spotify songs with each other, thereby creating a "digital scrapbook" of...
'Leaked' Images Allegedly Show iPhone 12 With Smaller Notch, Rear Camera Redesign, and Home Screen Widgets
Tuesday April 7, 2020 4:28 am PDT by Tim Hardwick
Two images shared on social media this morning are currently stoking speculation about possible hardware redesigns coming to the iPhone 12 and the potential introduction of Home screen widgets in iOS 14. Shared by Twitter user Fudge (choco_bit), the images depict a front and rear graphical representation of a smartphone with interface elements on the screen, suggesting it came out of a...
LG Begins Rolling Out 2020 NanoCell TVs With AirPlay 2 and HomeKit, Pricing Starts at $599
Thursday April 9, 2020 7:32 am PDT by Joe Rossignol
LG today announced pricing and availability for its 2020 NanoCell TVs with AirPlay 2 and HomeKit support in the United States. The first 4K models are rolling out now, with pricing starting at $599 for a 55-inch model. The entire 4K lineup will be released by September, including up to an 86-inch model for $3,299. 8K models will also be rolling out in May and June, including 65-inch and...
Apple Releases iOS and iPadOS 13.4.1 With Fix for FaceTime Bug
Tuesday April 7, 2020 10:06 am PDT by Juli Clover
Apple today released iOS and iPadOS 13.4.1, minor updates that come two weeks after the release of iOS and iPadOS 13.4, major updates that introduced iCloud Folder Sharing, a new Mail toolbar, trackpad support for the iPad, and more. The iOS and ‌iPadOS‌ 13.4.1 updates are available on all eligible devices over-the-air in the Settings app. To access the updates, go to Settings > General...
Leaker Claims New 13-inch MacBook Pro Coming as Soon as Next Month
Monday April 6, 2020 2:56 am PDT by Tim Hardwick
Apple will announce a new 13-inch MacBook Pro in May with the codename J223, according to a rumor shared by YouTuber and leaker Jon Prosser. Note: it’s a refresh to the current 13” So the bigger 14” display upgrade is a big possibility— Jon Prosser (@jon_prosser) April 4, 2020 Analyst Ming-Chi Kuo has said Apple plans to release new MacBook Pro and MacBook Air models with scissor keyboards ...
Apple Reportedly Targeting WWDC for Over-Ear Headphones Launch, New 'AirPods X' Later in the Year
Tuesday April 7, 2020 7:00 am PDT by Eric Slivka
Rumors of Apple-branded over-ear headphones have been circulating for quite some time, while more recent rumors have mentioned an "AirPods Pro Lite" that could also be in the works, and Twitter leaker Jon Prosser's recent foray into Apple rumors provides a bit more detail on what we might able to expect for these products. Current Beats Studio3 Wireless and BeatsX On the over-ear side,...
2020 iPad Pro Confirmed to Lack a U1 Ultra Wideband Chip
Tuesday April 7, 2020 7:52 am PDT by Eric Slivka
Last week, we laid out evidence suggesting that the just-released iPad Pro models do not contain a U1 Ultra Wideband chip, including the lack of any mention of the chip in tech specs or Apple's press materials, the absence of software support for U1 features, and more. Most tellingly, iFixit was unable to find the chip or related antennas in the device. Daring Fireball's John Gruber has follo...
Apple Shares Assembly and Use Instructions for New Face Shields, Shipping 1 Million Per Week to Medical Workers
Tuesday April 7, 2020 8:54 am PDT by Eric Slivka
Following this weekend's news from Tim Cook that Apple is working with its supply chain to produce a million face shields per week for medical workers, the company has shared a support document outlining how to assemble and adjust the shields. The document includes a series of images and animations showing how the simple three-piece product can be assembled for either a regular fit or with...
HBO GO and HBO NOW Will No Longer Be Available on 2nd and 3rd Gen Apple TVs Starting April 30
Wednesday April 8, 2020 7:05 am PDT by Joe Rossignol
HBO today announced that its HBO GO and HBO NOW streaming services will no longer be available on second-generation and third-generation Apple TV models starting April 30, 2020. In a support document on its website, HBO says this change is being made "in order to provide the best streaming experience":In order to provide the best streaming experience, we need to make some changes to our...
