AirPods Pro 2 vs. AirPods Max Buyer's Guide
Almost three years after the launch of the first-generation AirPods Pro, Apple unveiled the second-generation model alongside the iPhone 14 lineup and several new Apple Watches. Although the second-generation ‌AirPods Pro‌ feature the same design as their predecessor, they improve on features like Active Noise Cancellation, in-ear detection, and battery life, while introducing new functionality like Adaptive Transparency, volume adjustment touch controls, and precision finding.
airpods max blue image
In late 2020, Apple announced the AirPods Max, a whole new AirPods variant with an over-ear design. Both the ‌AirPods Max‌ and the ‌AirPods Pro‌ feature Active Noise Cancellation, Personalized Spatial Audio with dynamic head tracking, Hey Siri, and automatic switching.
As the two high-end AirPods options, should you consider purchasing the $249 third-generation ‌AirPods Pro‌, or do you need the ‌AirPods Max‌, which sell for $549? Our guide helps to answer the question of how to decide which of these AirPods are best for you.
Differences
Second-Generation AirPods Pro
  • In-ear design with silicone ear tips (four sizes)
  • Vent system for pressure equalization
  • Plastic design
  • IPX4 sweat and water resistant earbuds and charging case
  • Force sensors and touch controls for volume adjustment
  • Custom high-excursion Apple driver and high dynamic range amplifier
  • Dual beamforming microphones
  • Inward-facing microphones
  • Skin-detect sensors
  • Motion-detecting accelerometer
  • Speech-detecting accelerometer
  • H2 chip
  • Bluetooth 5.3
  • Transparency and Adaptive Transparency
  • Conversation Boost
  • Up to 5.5 hours listening time with with Spatial Audio enabled
  • Up to 4.5 hours of talk time with a single charge
  • Up to 24 hours of talk time using MagSafe Charging Case
  • ‌MagSafe‌ Charging Case with built-in speaker for Find My, U1 chip for Precision Tracking, and lanyard loop
  • ‌MagSafe‌ Charging Case compatible with Apple Watch charger, ‌MagSafe‌ charger, Qi wireless charging mats, and Lightning
  • Available in White only
  • $249
AirPods Max
  • Over-ear design with magnetic ear cups
  • Aluminum, stainless steel, and silicone design
  • Noise control button and Digital Crown for volume adjustment
  • Apple-designed dynamic driver
  • Nine microphones (eight used for Active Noise Cancellation, three used for voice pickup)
  • Optical IR sensors
  • Accelerometer
  • Position sensor
  • Case-detect sensor
  • H1 chip
  • Bluetooth 5.0
  • Transparency
  • Up to 20 hours of listening time on a single charge with Active Noise Cancellation or Transparency mode enabled
  • Smart Case to preserve battery charge in ultra-low-power state
  • Charge via Lightning only
  • Available in Silver, Space Gray, Sky Blue, Pink, and Green
  • $549
While there is some overlap between the ‌AirPods Pro‌ and ‌AirPods Max‌ with features like Active Noise Cancellation and Transparency, the entirely different fit and form factor of the headphones should make it easier for most customers to decide which device they prefer.
The ‌AirPods Max‌ offer a wide range of color options and a more premium design, as well as much longer continuous battery life with a single charge. Owing to its over-ear design and significantly larger drivers, the ‌AirPods Max‌ deliver markedly better audio quality than the ‌AirPods Pro‌. If your main priority is audio quality, the ‌AirPods Max‌ will undoubtedly be the best choice. If you actively dislike the in-ear design of the ‌AirPods Pro‌, the ‌AirPods Max‌ may also be more comfortable.
On the other hand, the ‌AirPods Pro‌ offer a high-level of convenience and portability due to their small size and charging case. The audio quality of ‌AirPods Pro‌ cannot rival ‌AirPods Max‌, but new features like Adaptive Transparency are ideal for when you're on the go. Due to their lightweight, in-ear design and sweat and water resistance, the ‌AirPods Pro‌ are also perfect for workouts.
The ‌AirPods Pro‌ are much more versatile when it comes to charging, with four different ways to charge, compared to the ‌AirPods Max‌'s obligatory Lightning port option. Due to their size, weight, less durable design, and limited portability, the ‌AirPods Max‌ are best used at home for high-fidelity, prolonged listening sessions, while the ‌AirPods Pro‌ offer a more balanced experience with a high level of convenience and portability.
AirPods frequently see hefty discounts on Amazon and other third-party retailers, so stepping up to the Max version may be more worth it if you can take advantage of one of those deals. Both sets of AirPods often see solid discounts, so it is always worth seeking the best price using our Deals roundup.
Related Roundups: AirPods Pro, AirPods Max
Related Forum: AirPods
Top Rated Comments
rmsanger Avatar
8 weeks ago
another over ear option:
https://forums.macrumors.com/threads/focal-bathys-hi-fi-bluetooth-anc-headphones.2364276/?post=31597421#post-31597421
Related Stories
airpods 3 purple
AirPods 3 vs. AirPods Pro 2 Buyer's Guide
Friday September 23, 2022 12:04 pm PDT by
Almost three years after the launch of the first-generation AirPods Pro, Apple unveiled the second-generation model alongside the iPhone 14 lineup and several new Apple Watches. Although the second-generation AirPods Pro feature the same design as their predecessor, they improve on features like Active Noise Cancellation, in-ear detection, and battery life, while introducing new functionality...
airpods pro 2
AirPods Pro vs. AirPods Pro 2 Buyer's Guide: Should You Upgrade?
Wednesday September 14, 2022 4:07 pm PDT by
iPhone 14 multicolored feature single pill
What to Expect From the September 7 Apple Event: iPhone 14, Apple Watch Series 8 and More
Friday September 2, 2022 10:32 am PDT by
Apple's annual iPhone-centric fall event is set to begin on Wednesday, September 7, and unlike last year, there will be an in-person component with members of the media invited to test out new devices. We've been hearing rumors about the next-generation iPhones for many months now, so we know the ins and outs of what to expect. Subscribe to the MacRumors YouTube channel for more videos. This...
iOS 16
iOS 16.1 Features: Everything New in iOS 16.1
Monday October 24, 2022 2:33 pm PDT by
Apple today released iOS 16.1 to the public after a little over a month of beta testing, adding essential new features to the iOS 16 operating system and debuting a version of iPadOS 16 for the first time. iOS 16.1 adds features that were delayed from the iOS 16 update, plus it tweaks some existing capabilities and interface options. We've outlined everything new in iOS 16.1 below. iCloud ...
iphone 14 pro max deep purple
iPhone 14 Plus vs. iPhone 14 Pro Max Buyer's Guide
Friday September 16, 2022 6:34 am PDT by
The iPhone 14 Plus and iPhone 14 Pro Max are among Apple's latest iPhone models and follow last year's iPhone 13 mini and iPhone 13 Pro Max. Now that Apple is offering two iPhones with 6.7-inch displays, how different are the two models, and what exactly does a "Pro" device give you? Last year, the biggest differences between the iPhone 13 and iPhone 13 Pro were ProMotion, 2GB of memory,...
ios 16 lock screen feature2
iOS 16: 15 Tips to Make Your iPhone Battery Last Longer
Friday November 4, 2022 2:35 pm PDT by
With each new operating system update, there are complaints about battery life, and iOS 16 is no exception. There are oftentimes periods of rapid battery drain after an update due to behind the scenes syncing and updating, but sometimes problems can persist longer. Battery life problems can be caused by new features Apple has implemented, bugs that need to be fixed, or simply an uptick in...
iPad Pro 2022 vs Air Feature
2022 M1 iPad Air vs. M2 iPad Pro Buyer's Guide
Friday October 28, 2022 8:13 am PDT by
Apple's latest iPad Air and iPad Pro models feature similar designs, Liquid Retina displays, M-series chips, 5G connectivity, and much more in common – so which should you buy? The introduction of the previous, fourth-generation iPad Air in September 2020 brought the device much closer to the iPad Pro in terms of design, and with the most recent model, the iPad Air gained the same M1 chip as ...
iphone se 1
iPhone SE vs. iPhone 12 Buyer's Guide: Comparing Some of Apple's Cheapest iPhones
Wednesday October 5, 2022 2:21 am PDT by
The third-generation iPhone SE and the iPhone 12 are now among Apple's lowest-cost iPhone options, starting at $429 and $599 respectively. Apple released the iPhone 12 in late 2020, and has bumped it down in price since then to make it more accessible as new iPhone models have been released. On the other hand, the third-generation iPhone SE launched in early 2022, refreshing the most affordable...
Popular Stories
iOS 16
Apple Releases iOS 16.1.2 With Carrier Improvements and Crash Detection Optimizations
Wednesday November 30, 2022 10:09 am PST by
Apple today released iOS 16.1.2, another minor bug fix update that comes one week after the release of iOS 16.1.1 and three weeks after the launch of iOS 16.1, an update that added support for iCloud Shared Photo Library, Matter, Live Activities, and more. The iOS 16.1.2 update can be downloaded on eligible iPhones over-the-air by going to Settings > General > Software Update. According...
Emergency SOS via Satellite iPhone YT
Apple's iPhone 14 Emergency SOS via Satellite Feature Saves Stranded Man in Alaska
Thursday December 1, 2022 4:37 pm PST by
With the launch of iOS 16.1, Apple rolled out a Emergency SOS via Satellite, which is designed to allow iPhone 14 owners to contact emergency services using satellite connectivity when no cellular or WiFi connection is available. The feature was put to the test in Alaska today, when a man became stranded in a rural area. In the early hours of the morning on December 1, Alaska State Troopers ...
General iOS 16 Feature Yellow
iOS 16.2 for iPhone Launching This Month With These 8 New Features
Thursday December 1, 2022 8:44 am PST by
Apple plans to publicly release iOS 16.2 for the iPhone in mid-December, according to Bloomberg's Mark Gurman. The update remains in beta testing for now, with at least eight new features and changes already uncovered so far. iOS 16.2 introduces a number of new features, including Apple's new whiteboard app Freeform, two new Lock Screen widgets for Sleep and Medications, the ability to hide...
applefifthavenue
Man Robbed After Buying 300 iPhones From Apple Fifth Avenue
Tuesday November 29, 2022 11:54 am PST by
An unnamed 27-year-old man who purchased 300 iPhones from Apple Fifth Avenue on Monday morning was robbed shortly after leaving the store, according to 1010Wins Radio in New York. He was carrying 300 iPhone 13s in three bags and walking to his car at 1:45 a.m. when another car pulled up next to him. Two men jumped out and demanded that he hand over the bags. Not wanting to hand over 300...
14 vs 16 inch mbp m2 pro and max feature 1
'M2 Max' Geekbench Scores Leak Online, Revealing Rumored Specs and Performance
Wednesday November 30, 2022 2:39 am PST by
Geekbench scores allegedly for the upcoming "M2 Max" chip have surfaced online, offering a closer look at the performance levels and specific details of the forthcoming Apple silicon processor. The Geekbench results, first spotted on Twitter, are for a Mac configuration of with the M2 Max chip, a 12-core CPU, and 96GB of memory. The Mac listed has an identifier "Mac14,6," which could be...
iPad 10 Battery Pull Tabs
iPad 10 Teardown Reveals Why Device Isn't Compatible With Apple Pencil 2
Thursday December 1, 2022 10:48 am PST by
Do-it-yourself repair website iFixit today shared a video teardown of Apple's new 10th-generation iPad, providing a closer look inside the tablet and revealing why the device lacks support for the second-generation Apple Pencil. The teardown reveals the internal layout of the iPad, including its two-cell 7,606 mAh battery, logic board with the A14 Bionic chip, and more. As suspected, the...
Apple Park View
Elon Musk Meets With Apple CEO Tim Cook Amid Claims of Twitter App Store Dispute [Updated]
Wednesday November 30, 2022 12:43 pm PST by
Twitter CEO Elon Musk today met with Apple CEO Tim Cook at the Apple Park campus in Cupertino, California, according to a tweet shared by Musk this afternoon. Musk thanked Cook for taking him around Apple's headquarters, with no mention of what the two might have discussed. The meeting comes just after Musk on Monday claimed that Apple has "mostly stopped" offering ads on Twitter, and that...
eufy camera
Anker's Eufy Cameras Caught Uploading Content to the Cloud Without User Consent [Updated]
Tuesday November 29, 2022 1:01 pm PST by
Anker's popular Eufy-branded security cameras appear to be sending some data to the cloud, even when cloud storage is disabled and local only storage settings are turned on. The information comes from security consultant Paul Moore, who last week published a video outlining the issue. According to Moore, he purchased a Eufy Doorbell Dual, which was meant to be a device that stored video...
app store awards 2021
Apple Announces 2022 App Store Award Winners, Highlighting Best Apps of the Year
Tuesday November 29, 2022 3:10 am PST by
Apple today announced its 2022 App Store Award winners, highlighting the 16 best apps and games selected by Apple's global App Store editorial team. The top apps were chosen by Apple for their quality, innovative technology, creative design, positive cultural impact, and ability to deliver "exceptional experiences." Apple CEO Tim Cook said: This year's App Store Award winners reimagined...
iOS 16
Apple Still Has These 5 Things to Release Heading Into 2023
Thursday December 1, 2022 7:12 am PST by
The calendar has turned to December and that means Apple has only one month left to fulfill its promises of releasing an Apple Music Classical app and expanding its self-service repair program to Europe before the end of 2022. Delays are always possible, of course, so the plans could be pushed back to 2023. In any case, we have put together a list of five things that Apple still has to release...
